es300 2000 with 138,000 hard brakes and rough/low power engine
Old 10-17-14 | 08:29 AM
VICIII's Avatar
VICIII
Default es300 2000 with 138,000 hard brakes and rough/low power engine
Not sure what is going on.
Brakes were first to notice that they became hard like to power assist.
Then rough idle to lack of power. Clunks from the engine area, not sure if trans or just engine missing so it is making noise.
No codes that say coil pack.
Got the code read and they guy just said air sensor.
Ran perfect before then poof....
I have had a Cam valve replaced and it runs kind of like that but lot less power and hard brakes.
Anyone else have this?
Old 10-17-14 | 06:42 PM
speedkar9's Avatar
speedkar9
You probably have a vacuum leak in the intake system. Given the brakes aren't working properly, my thoughts are there's a leakage in the brake booster vacuum line going to the intake, if not a leakage in the booster itself.
Old 10-17-14 | 08:19 PM
Hayk's Avatar
Hayk
+1 Check your brake booster line.
Old 10-19-14 | 12:33 AM
Mrv8q's Avatar
Mrv8q
Ignition coils. Look again for 301-306 codes.
Old 10-27-14 | 10:24 AM
VICIII's Avatar
VICIII
Thanks for the replies. I am out of town but will be tackling this when I get back and keep you posted. Thanks again for the info.
RXSF
Hybrid Technology
15
02-19-13 03:41 PM
SaleenS7
16
12-20-12 03:07 PM
Lexs400
Maintenance
05-05-05 04:34 PM
ChaosOrion
Suspension and Brakes
07-30-04 02:50 PM
TRiis2004
SC- 1st Gen (1992-2000)
01-13-02 05:22 PM
