es300 shopper
#31
good to hear you got one...I love to see the postings of Lexus cars for sale from Florida....
Like looking at a Lexus Calendar.
#32
I just bought an '02 with 133K for 8K. IMO was a great deal. I did a motor flush as I do with every car I purchase. I also did a Tranny fluid and filter change. I do own an OBDII scanner/reseter and it was clean. Other than that you should be able to kick the tires and test drive it for any weird sounds and make a decision.
#33
I think I have found the info I was looking for...this is a record of Lexus items/repairs that were listed on a CarfaX for a 1999 Es with about 100,000 miles on it.
96,802 Arrowhead Lexus
Peoria, AZ
623-872-4000
arrowheadlexus.com .
Front brake pads replaced and rotors resurfaced
Front brakes replaced
11/28/2008 98,128 Arrowhead Lexus
Peoria, AZ
623-872-4000
arrowheadlexus.com Starter replaced
Battery/charging system checked
05/27/2009 100,089 Arrowhead Lexus
Peoria, AZ
623-872-4000
Lower control arm(s) replaced
Front shock absorber(s) replaced
Valve cover gasket(s) replaced
Engine mount(s) replaced
Stabilizer bar bushings replaced
Four wheel alignment performed
Control arm(s) replaced
Rear shock absorber(s) replaced
Steering/suspension checked
03/26/2010 103,055 Arrowhead Lexus
Peoria, AZ
623-872-4000
Engine checked
08/31/2010 105,000 Arizona
Inspection Station
Maricopa County Passed emissions inspection
09/19/2011 108,173 Arrowhead Lexus
Peoria, AZ
623-872-4000
arrowheadlexus.com 15,000 mile service performed
Cabin air filter replaced/cleaned
09/06/2012 110,000 Arizona
Inspection Station
09/27/2013 113,230 Arrowhead Lexus
Peoria, AZ
623-872-4000
arrowheadlexus.com 120,000 mile service performed
Timing belt replaced
Drive belt(s) replaced
09/08/2014 116,000
Arizona
Inspection Station Passed emissions inspection
Peoria, AZ
623-872-4000
Peoria, AZ
623-872-4000
Peoria, AZ
623-872-4000
Peoria, AZ
623-872-4000
Engine checked
Inspection Station
Peoria, AZ
623-872-4000
Inspection Station
Peoria, AZ
623-872-4000
09/08/2014 116,000
Arizona
#34
Here's a similar list of things that needed servicing on a under 100,000 mile ES 300car from California
87,322 Daniels Tire Service
Bermuda Dunes, CA
888-347-0646
Tire condition and pressure checked
Oxygen sensor replaced
Fuel injection system flushed/serviced
Intake manifold gasket(s) replaced
Water pump replaced
Antifreeze/coolant flushed/changed
Strut mount(s) replaced
Brake fluid flushed/changed
Transmission fluid changed
Bermuda Dunes, CA
888-347-0646
Water pump replaced
#35
ok then, thanks for all the input on buying a used Lexus ES300. Learned a lot and it seems I'm not the only one looking for advice on the same matter.
After sifting through the reply's, the best choices from Lexus owners of the ES series leaned toward the 1998 to 2001's for various practical reasons. From better transmissions in some, to year to year component improvements and some reasons just based on upgraded options..(Like the 2000 to 2001's) So long story short, I finally found one in the color and option package I was looking for (Crystal white, Platinum package with beautiful chrome wheels, wood trim interior, and gold badges.
Mileage 117,000..timing belt done at 87,000 and a pile of work orders and receipts for all other work done. New OEM floormats, current service up to date, good tires and brakes, no CEL's. and a rust free no dings or nasty stuff Carcheck West Coast one owner history, for $5500.00
Thanks again for all the comments and patience from the Lexus Club Forum members.
intermec
07-15-09 02:28 PM
Steve Barnes
11-20-01 01:35 PM
