1993 ES300 - How do you remove front rotors?
Thought replacing front rotors would be easy but guess it isn't. Can anyone tell me how to remove front rotors?
Thanks,
Jim
Thanks,
Jim
Thanks,
My rotors are obviously rusted solid on the hub. Big hammer doesn't do a thing. However, after talking to my local mechanic, I now know what the two threaded holes are for on face of rotor.
RTIS250 (12-21-09), also had the answer, here it is:
"And for the record. After removing the caliper and bracket, there is nothing holding the rotor to the hub but rust. There will be 2 holes that are threaded on the hub face of the rotor. A 12mm head/10mm shaft .125 thread (pretty sure thats right) bolt can be run into the hole to push the rotor off of the hub."
__________________
Read more: https://www.clublexus.com/forums/mai...#ixzz3OHEJBKcp
__________________
Thanks,
__________________
__________________
tmorales
04-05-04 10:23 AM
