Price discrepancy in dogbones
Old 01-09-15, 06:14 AM
acarapella
acarapella's Avatar
Default Price discrepancy in dogbones
Hello. My motor moves like 3 inches when shifting from park to reverse. Probly time for a mount. OEM Lexus on eBay is like $85. Napa and autozone is $90. eBay generic is $18. Does the quality matter that much here?
Old 01-09-15, 06:43 AM
hypervish
hypervish's Avatar
I believe it does. Some people have mentioned that cheap dogbone mounts result in more vibration.
I went with OEM, and got one for $62.70 on eBay from seller "lexusofnorthmiami".
Old 01-09-15, 09:29 AM
acarapella
acarapella's Avatar
Yike. Don't want vibration. I'll go oem. After you changed it, how much movement do you get, say, shifting from park to reverse
Old 01-09-15, 09:45 AM
hypervish
hypervish's Avatar
About an inch, give or take.
Be sure to inspect all of the other mounts, I've been told, if one mount fails the others will likely follow due to the added pressure.
Old 01-09-15, 10:06 AM
acarapella
acarapella's Avatar
Great. so for I am not off to a good start with this car. I've had it 31 days and am dealing with an exhaust leak where the oem part is $1,300 and I replaced steering line.... Dealt with a clunk in the steering column and now this. Yikes.
Thanks for the heads up
What's an easy way to check them?
Old 01-09-15, 12:11 PM
Oro
Oro's Avatar
I inspected an OE one, a $20 one, and an expensive one (NAPA) and could find no difference.
I put an inexpensive one in mine last year and it works perfectly - I get MUCH less than an inch of movement if someone shifts while I observe it. If it's still moving that much, I suspect other mounts are bad, too, not just that one.
Old 01-09-15, 05:11 PM
speedkar9
speedkar9's Avatar
Personally, I would cheap out on the dog-bone mount just because its so simple to change a new one when it goes.
However I think OEM is the wiser choice for the rear and front engine mounts.
Old 01-10-15, 07:40 AM
lostape45
lostape45's Avatar
I used a $20 one from eBay and mine has been holding up just fine. I don't think the quality is all that different, it's more of a personal preference.
Old 01-11-15, 06:33 PM
JetsonES
JetsonES's Avatar
A $1300 exhaust leak, what in the?!
Old 01-11-15, 08:22 PM
acarapella
acarapella's Avatar
Look at Sewell Lexus parts. $1,381 for the y/flex/cat pipe if you go oem which I will not
Old 01-14-15, 02:17 PM
acarapella
acarapella's Avatar
Fyi: just put in an $18 Chinese one. Less vibration than I would expect for a v6 at 12 years old. WAY tighter/smoother shifting. Great $18 investment
Old 01-14-15, 04:03 PM
JetsonES
JetsonES's Avatar
Great to hear. I love ~$20 mods. Got a link?
Old 01-14-15, 06:07 PM
acarapella
acarapella's Avatar
I may retract that statement - I'll let you know
Old 01-14-15, 06:18 PM
JetsonES
JetsonES's Avatar
Uh oh
Old 10-09-15, 05:55 PM
JetsonES
JetsonES's Avatar
Bring out your dead! Hey acarapela, how is the dogbone now that you've had it for almost a year? I still haven't done mine yet.
vollandt
10-07-16 02:20 PM
JohnLX300
RX - 1st Gen (1999-2003)
08-15-16 04:41 PM
t2d2
Performance & Maintenance
19
09-24-14 07:29 AM
PlotPoint
20
01-29-13 05:56 PM
LexChamp
08-13-10 05:32 PM
Quick Reply: Price discrepancy in dogbones
