99 ES 300 U140E interchange
Do people not understand how google works nowadays?
As per wikipedia. Any other auto resource such as car-part would show the same interchange!
Applications:
2002–2004 Camry (V6)
2001–2003 Highlander (V6)
1999-2003 Lexus ES 300
gear ratios: 1st 3.938, 2nd 2.194, 3rd 1.411, 4th 1.019, rev 3.141, final drive 2.814
I found the same thing when I googled it, but didn't quite believe that the 2002 and 2003 ES's had the same 4 speed auto tranny as the model year's prior. I was under the impression it had a 5 auto speed transmission.
Correct, the 2002 & 2003 ES300 have a 5 speed u151e transmission which is not interchangeable with the u140e.
A U140E by any other name... I think the only difference between the Camry and ES is the final drive and 1st gear ratio. This may cause issues with the ABS and TC systems tho. So I would say not to interchange. I just finished posting a video on here for someone showing how easy it is to rebuild one tho. In Japan, average citizens can rebuild them on their kitchen tables. This video is the A541E, but the two are similar.
Swapping in the U151E would require extensive work not even close to being practical.
So to clear the air, what transmission from other Toyotas is compatible with the 99 ES300 transmission? Meaning a direct swap?
Or just stick with the automatic transmission from a 99 to 01 ES300?
