Help! Engine Stutter, CEL and P0171 code
Old 04-25-15, 03:08 PM
tomf
tomf's Avatar
I think of the A/F sensor as a more sophisticated O2 sensor. They are not interchangeable. Here's a link explaning A/F sensors http://www.motor.com/article.asp?article_ID=1643
Go to the Denso website to see which one you need. http://densoautoparts.com/find-my-pa...icle-selection
According to the Denso website, both your upstream sensors (Sensor 1) are A/F. Your downstream sensor (Sensor 2) is O2. Sensor 2 is on the exhaust pipe almost directly under the driver's seat.
If your error code is saying bank 1 sensor 1 (upstream rear) or bank 2 sensor 1 (upstream front) then you need the A/F. Note there are two different part numbers for the front and the rear upstream sensors.
turtlepeas (04-26-20)
Old 04-28-15, 09:43 AM
artbuc
artbuc's Avatar
Only because the original wiring harnesses were different lengths. Quite sure these two p/n's have been merged, at least they have been on most 1MZ-FE's.
Old 04-29-15, 04:25 PM
Mphidd
Mphidd's Avatar
I just had all three oxygen sensors replaced on my 99 ES300 and that fixed the problem!! I love being able to exchange stories on this forum so we can help each other
pchouston
RX - 1st Gen (1999-2003)
02-10-19 09:04 PM
mzeitlin
11-28-17 05:26 AM
Rollaboy
02-21-11 01:43 PM
shahir18
IS - 1st Gen (2001-2005)
12
01-30-11 07:07 PM
Quick Reply: Help! Engine Stutter, CEL and P0171 code
