1999 es300 transmission
Old 02-27-15, 07:40 AM
curtissher
curtissher's Avatar
Default 1999 es300 transmission
engine idles rough at times. engine will shut off at times. trans wont shift to o/d.
Old 02-27-15, 11:25 AM
ES300NZ
ES300NZ's Avatar
based on the information you provided, I think the tyres are the problem.
Old 02-27-15, 02:50 PM
tomf
tomf's Avatar
Check for pending or actual errors with an OBD II reader. Sounds to me like you have a problem other than the transmission. Is the CEL on? Any other error lights on?
Old 02-27-15, 06:18 PM
speedkar9
speedkar9's Avatar
I'm going to take a wild stab at it and say its your engine temperature sensor malfunctioning. The engine is trying to over compensate to put more fuel and air into a warm engine causing rough idling and also preventing the transmission from shifting into O/D since the engine is cold.
EdgarLex
11-22-18 08:36 PM
jsp973
06-24-17 04:12 AM
pruietjr
10-10-16 06:05 PM
harryb5a4
03-13-15 07:04 AM
cdvmagic
Maintenance
12-16-06 03:25 PM
Quick Reply: 1999 es300 transmission
