wheel help please
wheel help please
My stock wheels on my es 330 are flaking and have some curb rash. I found a set of toyota highlander wheels 17 inch in great shape. will the centerbore be the same diameter? I know the highlander wheel has a centerbore of 60.1 mm. I dont know the centerbore of the es wheels. thanks
Jim
Jim
Wheels
Thanks. The highlander wheels are from a 2011. I checked the bolt pattern I should be good. I found a offset calculator and it looks like the wheel will stick out 8.5 mm more towards the fender lip and 4.5 mm more towards the strut. That is not much so I am hoping I will have clearance.
Jim
Jim
Wheel offset
The stock wheels are supposed to be 7x17j et 37
Well I pulled my spare out and it turns out it has a 50mm offset. Bummer I now think the highlander wheels would move my tires out about .820" Now I am not so sure I would have clearance. Anyone need some really nice toyota Highlander wheels ? :-)
The stock Lexus ES330/350 wheels are 17x7" with a 50mm offset.
The Highlander wheel at a 35mm offset would mean your wheel would stick 15mm outward (away from the strut, toward the fender).
You can take some measurements to see if it will fit your fender, otherwise you could roll your fenders to clear the tires. My gut feeling is it shouldn't be an issue.
I will have to put a tire on one of the wheels and put it on the front and try it to see if it rubs. It is gonna be close.
Jim
The_Hitman
Wheels, Tires & Brakes Forum
02-03-05 01:07 AM
