Help!
So I recently purchased a 2000 ES with 94k. I work for a Ford dealer so we took it in trade. Its a 2 owner super clean car. I noticed it needed valve cover gaskets so I had the toyota dealer do them. I have a leak that I cant find the source of. It is dripping on to the passenger CV shaft and I get an oil burning smell at idle throught the heat vents when the heat is on. We have put dye in the oil and power steeering to see if we can spot the source. The oil or so I think its motor oil seems to be dripping down the steering pump on to the cv shaft but neither seem to be low. I am just curious if anybody else has had a similar problem and knows anything to help out. We have had the car up on the lift running for an hour and still couldnt tell. Maybe a cam seal? Thanks
