Best way to clean the power socket nipple?
Old 03-18-15, 01:28 PM
Fritz330
Fritz330's Avatar
Default Best way to clean the power socket nipple?
Mine is corroded and it's hard to get anything to connect and stay connected. Is there a preferred cleaning method/cleaner? Should I coat it with grease after cleaning?
Thanks
Old 03-18-15, 01:47 PM
PFB
PFB's Avatar
Thanks
I assume you're taking about the 12V power outlet socket. The best way to clean its internal contacts is with a small pencil eraser. When done, remove or vacuum out any left over eraser pieces.
Once clean, you can than spray some plastic safe electrical contact cleaner on its contacts.
Phil
Old 03-20-15, 06:49 PM
speedkar9
speedkar9's Avatar
+1 on the pencil eraser.
You can also use electrical contact cleaner, or if its really corroded some sandpaper/ emery cloth to abrade the connection.
Old 03-21-15, 07:53 AM
Fritz330
Fritz330's Avatar
Gonna try the pencil eraser and contact cleaner first. I did think about sand paper or a Dremel with a suitable attachment but thought there might be a special coating on it like silver to enhance the contact and I didn't want to remove it completely. Guess if push come to shove I can just replace it.
emosley
Automotive Care & Detailing
10-07-13 06:44 PM
hatteroo
04-07-13 08:18 AM
sallydrive
02-29-12 01:26 PM
LovetheLex
08-03-09 12:42 AM
is250rida
03-31-08 05:52 AM
Quick Reply: Best way to clean the power socket nipple?
