help (codes P0300, P0302, P0304, P0306, P0171, P1130, P1135, P1351, P1354)
codes P0300, P0302, P0304, P0306, P0171, P1130, P1135, P1351, P1354. Throttle almost 3/4 to floor it barely goes, once you get it past 3/4 it will throw you back in seat and go. could all this be from ECM?
Oil Control Valve (OCV): P1354 Lexus - Variable Valve Timing System Malfunction Bank 2
I lean toward the OCV. All the misfires are on bank 2. Replace the OCV and clean the OCV filter. It's about a 15 minute job.
You could have two problems. The second being the Air Fuel ratio sensor on bank 1. If replacing the OCV does't fix your problem replace the AF ratio sensor. But I'd guess the these errors will go away after you replace the bank 2 oil control valve.
