oil filter access panels 02-04 es
Old 05-12-15, 05:52 PM
Timothyj
Timothyj's Avatar
Default oil filter access panels 02-04 es
Hello, any problems to worry about if the oil filter access panels are removed? My 02 driver side panel is trashed, taped up for now, going to ordrer new ones. Thanks for any help with this.
Old 05-12-15, 07:14 PM
speedkar9
speedkar9's Avatar
Are you talking about the under body panels that bolt up against the bumper?
You don't need to remove any panels to access the oil filter on the ES300. The oil filter is accessed from the top of the engine bay, on the front of the engine block below the (hot) front exhaust manifold.
Old 05-12-15, 10:43 PM
Megafast13
Megafast13's Avatar
Yeah, not sure what you are referring to. We can access the oil filter from overhead. There is a tight space just enough to fit your forearms and/or a tool to remove the oil filter. Careful as he said though, the parts get a bit warm around the space!
Old 05-13-15, 04:14 PM
Timothyj
Timothyj's Avatar
It is the 2 panels that bolt up to the bumper. The drivers side was hanging down, its junk, just taped it up for now. Also, what are the best ramps for this car?
Old 05-13-15, 07:20 PM
BDSL
BDSL's Avatar
Just to clarify, there is no "oil filter access panel"....
To do oil change, you don't need ramps. It might be nice to have but I have done many engine oil and tranny oil changes on ES, Camry, MR2, Celica, Corolla, etc without rising the vehicle. You just have to reach in with a 14mm wrench to access the engine oil drain plug.
Old 05-14-15, 05:42 PM
Megafast13
Megafast13's Avatar
Oh! The 2 plastic panels that are attached to the wheel wells and front bumper are a huge pain. They don't have to be removed to perform an oil change, however most quick service shops either pry them open or improperly take them off and not install them back correctly for whatever reason.
If the are not properly secured the stance of the car does not look good, also the ground clearance is hindered.
Old 05-15-15, 03:51 PM
Timothyj
Timothyj's Avatar
O.K. thanks, so is there any harm to the car if I remove the one that is all beat up?
Old 05-17-15, 04:33 PM
Megafast13
Megafast13's Avatar
Not really. They are nice for keeping moisture and gunk from the streets from finding its way up into the engine bay, some may say they assist in airflow lol, but I only noticed that they quiet idle engine noise from outside the vehicle.
Old 05-20-15, 03:15 PM
Timothyj
Timothyj's Avatar
Thanks, I'm picking up the part Friday. Thanks for your help.
johnnieliu
06-16-13 12:37 PM
larrysb
IS F (2008-2014)
08-31-08 10:45 AM
ntran18
Maintenance
23
11-30-04 11:20 AM
kjbro
24
01-17-03 03:34 PM
lexian
RX - 1st Gen (1999-2003)
07-29-02 09:31 AM
Quick Reply: oil filter access panels 02-04 es
