2000 ES300 Steering Problem
I have 2000 ES300, I've notice this evening after turning my car and backing out of a parking spot that my steering was not normal. If the wheels are straight, and turn it a quarter(either direction right/left) I notice that it is bit rough/hard to turn at that quarter mark. I've checked the tires to see if the pressure wasnt too low and checked the power steering fluid as well-- seems to be at the right level.
I am able to drive the car and steer but it just has that rough/hard moment when I steer at either direction.
Please let me know if any of you have experience this before and how you tackled/recommend.
Trying spraying silicone on the steering shaft u-joints as they may be binding. There are u- joints in the interior above the brake pedal and in the engine compartment by the firewall.
^^^thanks for the info
i have the same issue on my 99, i have a PS leak and noticed this when i topped it off. first thing that came to mind was that my pump was going bad. hopefully its the U-joints as mentioned by HomerJay.
Follow up:
i purchased a can of liquid wrench and it fixed the issue. only thing is that it only lasts a few months before the issue returns. i don't mind spraying it when it needs it, but i just wish it would last a bit longer.
Liquid Wrench is a penetrating oil to break rusted nuts and bolts loose- no more lubricating than WD-40. You need to get a real lubricant - something like a sprayable thin grease.
Silicone spray and Lithium grease are both excellent. Silicone spray penetrates better, but Lithium grease lasts much longer. They're both safe for rubber.
JBLIZZ45
06-22-19 05:45 PM
lexuslove
01-11-13 11:18 PM
