1999 Lexus ES300 Broken Sensor Identification HELP
Old 06-10-15 | 06:04 PM
LexusOwn15's Avatar
LexusOwn15
Default 1999 Lexus ES300 Broken Sensor Identification HELP
Codes given are:
P 0125
P 1155
Bank: 2
Sensor: 1
I believe this sensor to be on the front of the engine of the car. Is this the oxygen sensor, or the air-fuel sensor? Also, is this considered the upstream or the downstream sensor?
Thanks!
Old 04-10-21 | 03:27 AM
Tooyotas's Avatar
Tooyotas
I'm reporting that I did Bob's modification successfully on a 2002 Toyota Highlander. (The black and clear wires were right where they were predicted to be.) There are pictures.
However, I used a "screw terminal block" to make it easier to restore the wiring to normal if the future requires replacing both sensors. (Grainger part# 6HY99)
I suspect the "knocks" the sensors are detecting may be "micro-knocks," similar to how ABS could be viewed as "micro-braking." I'm not one bit worried that my 225k+ engine will be "damaged" because a sophisticated car computer--which cannot determine that a sensor has failed in the first place--will make the wrong determination. I'll say this: the same computer was certainly destroying my transmission before the fix.
ayroman
12
12-04-23 04:00 PM
AndyG
23
04-15-22 08:36 AM
tommy329
11-27-17 05:21 AM
astroth
09-28-14 01:48 PM
imAC
04-17-13 08:19 PM
