OZ hub centric ring size queation
Hi All,
I just picked up a set of used OZ Racing F1 rims with Toyo Proxes T1R tires. The previous owner used them on a VW GTi, so they have a 57.06mm hub ring installed.
I want to use them on my 94 ES300. So, I am looking to buy a new set with ID 60.1mm. I measure the rim bore size with a tape; and I got 76mm.
I google and some people said OZ's bore size is 75mm; not 76mm. I don't have a precise guage; so I could be off by 1mm but not 100% sure.
I also notice that there are rings from 76mm to 60.1mm and rings from 75mm to 60.1mm. So, I am not sure which one to order. Just wonder if anyone has any experience with these rim.
Here are the spec from the previous owner
OZ Racing F1 rims
Rims: 17x7 ET35
Bolt Patterns: 5x100 and 5x114
Tires: Toyo Proxes T1R tires 225/45ZR17 94Y
Thanks in advance.
OZ Racing F1 rims
Rims: 17x7 ET35
Thanks in advance.
I got the answer. I email to the official OZ rim importer in Canada. They replied me back saying the center bore size is 75mm not 76mm. So, I should be looking for 75mm to 60.1mm ring.
Since I haven't mounted these rim and wheel, does anyone seeing any problem in the fitting? I hope they will fit. Thx.
