How to remove driver's side air vent outlet
Old 06-28-15, 05:37 PM
PFB
PFB's Avatar
Default How to remove driver's side air vent outlet
For some strange reason, something is wrong with my 2001 ES300 driver's side air vent. I can adjust it left or right, so the louvers work fine, but it won't move vertically properly. I assume that its held by a pin on each side, and that one of the pins may have broken, or came out of its respective mating hole. It's weird as I hardly ever, ever even move it.
Anyways, I would like to remove it, examine the cause, and try to fix it somehow.
So my question is: How do I remove it without any risk of damaging the vent any further?
Thanks,
Phil
Old 06-28-15, 06:02 PM
Megafast13
Megafast13's Avatar
At least on my 2002 there is a dash piece that includes the left vent. To remove it I had to partially remove the odometer cluster because each piece overlaps eachother if you will. I am not sure how the 2001 is designed some hopefully one of them will chime in. I wouldn't try to just pop out the movable piece of the vent, because they are a larger piece with a duct attached to them.
Old 06-29-15, 01:33 PM
PFB
PFB's Avatar
Thanks Megafast13. On my 2001, my vent is basically stand alone. I'm just not sure how to pull it out without causing anymore damage.
Phil
Ali SC3
Performance & Maintenance
09-17-13 01:26 PM
wildtigg3r
04-20-11 12:14 PM
Blueshark
ES - 5th Gen (2007-2012)
10-21-10 05:23 PM
lexus-is2
08-14-10 07:48 AM
Quick Reply: How to remove driver's side air vent outlet
