fuel filter
why do you need to change the fuel fitler?
from what i have seen toyota filteres are supposed to be lifetime ones
even the parts guy i know said he has only sold 3 in 6 years
There are a few Lexus techs (VVT-i, DevilDog, Sooner) who hang out in the the Maintenance Forum. I think I've seen them remark that the fuel filter is liftetime. If you run a search of that forum, you may come up with a thread with the answer to your question.
skperformance
I am not having any issues but my mpg has gone down a bit ,Maybe 1-2 miles per gallon . I figured would change them and the plugs with the weather getting better . Thanks and everyone play nice .
oh ok
well if you are doing just a basic tune up the filter should be fine unless you are running into hesitation problems from having really bad gas a few times (usually from little town gas stations at the side of the interetate,middle of no where)
otherwise just leave the fuel filter alone
just as a thought i would change the
air filter
the pcv valve can be cleaned very easily rather than being replaced
have the throttle body cleaned ,you can do it yourself with a can real easy.definatly peks an engine right up
oil change
and a good fuel injector cleaner
or see who in your area has a machine called a motor vac
it is a high pressure fuel system cleaner works worders
usually 100 canadain so about 60 usd
your gas mileage will jump drastically
also will help to clean the spark plugs( unless they are damaged ) to new and cat
if you end up doing the motor vac then do the oil change after it
as their willl be a little wash down from the cylinders to the oil
air filter
oil change
crisp76
12-28-11 08:44 AM
