post size of aftermarket rims fubbing question
Old 03-31-03, 02:08 PM
skperformance
skperformance's Avatar
Default post size of aftermarket rims rubbing question
just trying to get info
like this
to see what is a problem and not
size of :
tire (225/40-18 ,toyo T1-s)
width of rim (18X7.5)
offset (42mm)
and rubbing (none)
suspension height changes (eibach 1 inch drop, stock shocks)
one more thing is it rubbing on the inner or outer edge of the tire
Old 03-31-03, 02:11 PM
skperformance
could someone please make the spelling correction in the title as i can't
Old 03-31-03, 06:40 PM
MCV20
MCV20's Avatar
97 ES300
Brand: Dunlop FM901
Rims: 17" X 7.5 Heidfeld with 43 offset
Sup: KG/MM DR21 supersports (F: -40mm, R:-30mm), KYB GR-2 struts
Rubbing: none
Old 03-31-03, 08:42 PM
Kyle Harty
Kyle Harty's Avatar
92 ES
18x8 wheels
40 offset
225/40 Kumho tires
Suspension: B&G springs 1.6" drop, Tokico blue struts
rubbing: pretty minimal, only w/ weight in back
Old 03-31-03, 09:25 PM
Baby Lex
Baby Lex's Avatar
Unhappy
1995 ES300
18x8 Inch Wheels
42mm Offset (backspacing)
225/40/18 Kuhmo Tires
Eibach Pro-Kit 1" drop front & Rear
Tokiko struts at all 4 corners
RUBBING: Yes, not a whole lot. But it's there. It's worse if people are in the back. So I don't have them ride any more. I've notice it rubs jussst barely when taking corners at high speeds.
My assumption is that it rubs for most who use the wider rim, 8.0 and higher.
Old 04-01-03, 12:09 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
That's correct. Especially with a 235 width tire.
Old 04-02-03, 09:55 PM
MCV20
MCV20's Avatar
i have no rubbingat all.. with 235 tires.
here is the pic with 235 tires:
Attached Thumbnails post size of aftermarket rims fubbing question-heidfeld.jpg
Old 04-02-03, 09:56 PM
MCV20
MCV20's Avatar
REar
Attached Thumbnails post size of aftermarket rims fubbing question-heidfeld-1.jpg
Old 04-02-03, 10:01 PM
flipside909
Lexus Connoisseur
Do you get close when you have a load in the rear or taking corners hard?
Old 04-02-03, 10:30 PM
Baby Lex
Baby Lex's Avatar
Plus his are 17's. Not 18's.
Old 04-02-03, 11:48 PM
MCV20
MCV20's Avatar
i think the problem depends on the offset...mine were 43
before i had a set of rim...17" x 7 with 42 offset... it rubbing at the back like crazy with 235/45-17... on my accord...also i think the ES has bigger/wider fender flare then camry and accord..
nothing rubbing with load or taking corner....
i try to take some pic later on, to show u what is it look like on the side...
Mandin75
04-07-11 08:41 AM
Moosepower
IS - 1st Gen (2001-2005)
14
03-28-11 04:47 AM
abobiznow
07-08-09 12:26 PM
elclassico
Wheels, Tires & Brakes Forum
04-11-03 12:25 AM
MCV20
17
02-21-03 08:29 AM
Quick Reply: post size of aftermarket rims fubbing question
