97 Toyota Camry Es300 Ecm Ecu Computer Module?
Old 03-31-03, 07:50 PM
flipspeed
flipspeed's Avatar
Default 97 Toyota Camry Es300 Ecm Ecu Computer Module?
i saw this on ebay...
97 TOYOTA CAMRY ES300 ECM ECU COMPUTER MODULE
YOU ARE BIDDING ON AND ENGINE COMPUTER MODULE THAT FIT : CAMRY 97 Electronic Control Unit (ECU); (center of dash), 6 cyl, exc. CE; w/o traction control //// LEXUS ES300 97 Electronic Control Unit (ECU); (behind center of dash), w/o traction control
starting bid is about $36. my 98 es300 has no traction control. can it be installed? if so, im willing to take the gamble with the trd supercharger.
Old 03-31-03, 09:25 PM
Luc
Luc's Avatar
Uh...why would you want a Camry ECU whereas your ES will work just as fine? First off, the '97 CE V6 ECU has probably only 4 harnesses. Secondly, that's because no CE trims had climate control, and you will lose it in your ES in you do swap it. Take off the glovebox and CD changer (if present), and compared to this ECU. If it looks like this one, then you are fine.
Old 04-01-03, 12:17 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Default Re: 97 Toyota Camry Es300 Ecm Ecu Computer Module?
yeah it could, but why would you want to do such a thing? If you have a 97-98 ES300, that S/C bolts on perfectly...no need for extra electronics. Luc explained it pretty clear already.
rembo
03-09-23 12:43 AM
dds364
04-02-18 01:42 AM
ajs1391
03-01-16 08:26 AM
turbodremz
SC- 1st Gen (1992-2000)
02-08-10 02:40 PM
Quick Reply: 97 Toyota Camry Es300 Ecm Ecu Computer Module?
