how to change trans fluid
hey guys. where is the drain plug at and the place u fill it up at... i just cant seam to find it..
pics would be appreciated and how much does our trans need.. btw 95 es
Originally posted by skperformance
there is a hex nut screw not a bolt on teh bottom of the tranny pan
you fill it by using the dip stick tube
pics? aint it hard to pour down the dip stick tube
check the owners manual for exact fluid type should be dexron type 2
i can't say exact how much but 6 liters about
just drain and fill checking filling level after 5 liters
you need a tranny funnel to fill it
has a long goose neck to angle around
g4ebguy90
Performance & Maintenance
03-17-12 02:50 PM
