2005 es330 problems
I have problem with starting when car cold didn't start from first time it take two or three time to start but when i switch the car off and start again it start directly.
one more thing about the fuel filter location .
Start with the basics.
Make sure the battery terminals are on tight and not corroded.
If they are corroded, use some baking soda and water with a toothbrush to clean them up.
Check the terminals on the alternator and starter as well for corrosion.
You might want to take your battery to an auto-parts store for a load test. They'll charge it up then put a load on it to see if it retains its juice.
As an aside, keep the throttle body, idle air intake valve and mass airflow sensor clean, and make sure all tubes are intact with no cracks.
tomtsops
11-24-07 04:19 PM
