98 Lexus ES starting problem
Hey fellas I have a 98 Es and I have a weird starting issue. The car will start and run perfect until I shut it off and then the car will shutter and turn off unless I give it gas consistently for about a minute. I am not sure where to start. It also doesn't matter if I let the car run for a long time and shut it off or shut it off immediately.
is the starter dis-engaging ? sometimes they can run on, and stick in place. >- unlikely.
it could be stuck fuel injectors, it might be that they have glue like deposits in them, and need to be cleaned professionally.
It would also be worthwhile trying to pull any codes from the ecu.
Doc Yota
13
06-19-13 04:29 PM
porshapowe
02-24-07 08:36 PM
