turn signal dead
Old 04-06-03, 03:06 PM
obi-1
obi-1's Avatar
Unhappy turn signal dead
My turn signals on my 94 es 300 just stopped working i checked the fuse and its fine and the hazard lights still work I cant figure out the problem anyone got any suggestions??
Old 04-06-03, 06:52 PM
skperformance
skperformance's Avatar
if you press the hazard light button does it work?
do all the headlights and other lights work?
left and right side don't blink
Old 04-06-03, 07:13 PM
obi-1
obi-1's Avatar
yeah the hazard lights and all the other lights work but when i press the left or right turn signal it does nothing
Old 04-06-03, 07:25 PM
skperformance
have you checked the realy under thehood?
does the light on the dash even blink
if not it might be in the steering column where the problem is
Old 04-06-03, 08:56 PM
obi-1
obi-1's Avatar
no the lights on the dash dont blink when i try turning the turn signal on and the lights on the outside in the front and in the back dont go on. but the lights do blink when i turn my hazard lights on
Old 04-08-03, 12:28 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Default Re: turn signal dead
Turn signal relay is out. You can get a replacement for that. It's located in the fusebox on the drivers side fender in the engine bay.
Old 04-08-03, 04:16 PM
obi-1
obi-1's Avatar
thanks for the answer flipside909 i took a look at the fusebox on the drivers side fender in the engine bay but i didnt see any that said anything about turn or turn signal would you know which i should be looking for?
Old 04-10-03, 11:01 AM
obi-1
obi-1's Avatar
Talking
just wanted to let everyone know that i got my turn signals working again it was the turn signal flasher that needed to be replaced which is located in the driver side kick panel. I took the old one out put the new one in and it worked perfect.
obi-1
obi-1's Avatar
Talking
Old 04-10-03, 11:50 AM
flipside909
Lexus Connoisseur
Great to hear!
Old 08-04-11, 06:28 PM
griselda
griselda's Avatar
I am having the same problem with my turn signal. Can you tell me where the drivers side "kick panel" is located?
crenfro
SC- 1st Gen (1992-2000)
12
03-06-13 07:54 PM
Blizzy
15
08-08-07 07:56 AM
Quick Reply: turn signal dead
