es300 92 mystery connector
Old 09-20-15, 07:59 AM
candrade
candrade's Avatar
Default es300 92 mystery connector
Hello. Can anyone tell me whats this connector for? It comes from the wiring harness from the rear right of the intake manifold. Thanks
Old 09-20-15, 11:00 AM
JetsonES
JetsonES's Avatar
2 wires, yellow and yellow with a blue stripe? Hard to tell in the photo, most likely goes to a vsv somewhere close by.
Old 09-20-15, 11:37 AM
kolessc400
kolessc400's Avatar
Was it Pluged in before android an issue now
Old 09-20-15, 12:37 PM
candrade
candrade's Avatar
yes, those are the colors. i cant find anything near with that type of connector
i has been unplugged since i bought the car. right now i have a lot of problems:
-injectors #3 and #4 not getting pulse (ground)
-only troble code is 52 knock sensor
-once the cel comes on it begins to smoke a lot (white smoke from tailpipe)
Old 09-20-15, 01:08 PM
candrade
candrade's Avatar
injectors not getting pulse are 2 and 5
Old 09-20-15, 01:15 PM
JetsonES
JetsonES's Avatar
I am thinking it may be for the cruise control actuator. Here is a pdf for the wiring of the car:
File Type: pdf
Old 09-20-15, 02:24 PM
kolessc400
kolessc400's Avatar
You may have a couple bad injectors.. Did your car have cruiseship in the first place
Old 09-20-15, 06:13 PM
Received 2,826 Likes on 2,389 Posts
Not sure but it could be the connector that goes to the hydraulic solenoid on the power steering pump.
Old 09-20-15, 06:34 PM
candrade
candrade's Avatar
Great, may be it. Ill check that and let you know
es300majr
05-11-12 01:47 PM
DannyCO
07-08-11 11:55 AM
frednaz
10-13-10 07:53 AM
Quick Reply: es300 92 mystery connector
