es300 92 injectors #2 and #5 no ground pulse
Yes assuming the transistors or a suitable substitute is still available which I think is likely. ...almost forgot to say if you find someone to test the transistors also have them look for leaking capacitors.
Reading it again that is for the 2VZ-FE. Don't call other people out for not being skilled when you have trouble reading a simple document.
candrade
09-22-15 06:02 PM
SC300T
Performance & Maintenance
18
09-24-02 09:53 PM
