2000 Es - Ashtray lights?
Old 09-28-15 | 06:28 PM
funcrusher's Avatar
funcrusher
Default 2000 Es - Ashtray lights?
Is there only a light circling the lighter in the pop out ashtray area? Or is it the actual ashtray lit up also?
Old 10-01-15 | 05:21 PM
plovell's Avatar
plovell
Mine has a small clear plastic plate on the back of the ashtray. There is a bulb behind that.
Old 10-01-15 | 05:28 PM
funcrusher's Avatar
funcrusher
How do you replace that? The bulb isnt on the actual ashtray is it
Old 10-01-15 | 05:33 PM
808mcv20l's Avatar
808mcv20l
In my 99 Camry it was mounted in the frame above the actual ashtray, you need to pull the frame to swap it, once you get the frame surround out you twist and pull it out, it's a tiny wedge bulb like the one used the in the key hole ring.
I swapped it to an LED.
haven't had to replace the one in the ES yet.
Old 10-02-15 | 02:41 PM
funcrusher's Avatar
funcrusher
Damn how the hell do i pull that out
Old 10-02-15 | 02:51 PM
JetsonES's Avatar
JetsonES
This document should help:
File Type: pdf
wissam1218
01-09-18 12:20 PM
RXGS
Lighting
15
12-01-07 07:29 PM
abobiznow
01-08-07 01:11 PM
Quick Reply: 2000 Es - Ashtray lights?
