lexus es300 with 300zx wheels
Old 10-06-15, 12:44 AM
vietbboy85
vietbboy85's Avatar
Default lexus es300 with 300zx wheels
My 99 lexus es300 oem wheels are junk. I got is wheels from a nissan 300zx non-turbo for $60, and it looks awesome on my es300, brand new tires 205/60/16, No spacer needed.
Old 10-06-15, 01:24 AM
gabzor
gabzor's Avatar
That looks great! great job!
Old 10-06-15, 07:33 AM
JetsonES
JetsonES's Avatar
That looks great! And 60 bucks is a no brainer, that's like scrap prices. Did they come with tires too?
Old 10-06-15, 11:16 AM
vietbboy85
vietbboy85's Avatar
No, its doesnt come with tires, just for the wheels.
Old 10-06-15, 12:06 PM
JetsonES
JetsonES's Avatar
Still a steal at that price. I love the 5 spoke design, excellent fitment too. Did you use hubcentric rings as the center bore is 6mm larger?
Old 10-06-15, 06:02 PM
vietbboy85
vietbboy85's Avatar
Yes, i did install the hubcentric ring 60mm id 66mm od from ebay. id
Old 10-06-15, 07:17 PM
JetsonES
JetsonES's Avatar
Awesome, sounds like you're good to go and they really look spectacular on the car with the offset. Great find.
Old 10-06-15, 08:15 PM
speedkar9
speedkar9's Avatar
Looks great.
How'd you get the stock Lexus emblem to pop in?
I would have thought the 300ZX would have had much wider wheels, or even stanced, being a RWD car.
Old 10-07-15, 04:51 AM
vietbboy85
vietbboy85's Avatar
it was the stock wheels hub cap from my es300, its just pop right in, its just loose a little bit, but its not going anywhere though.
300ZX non-turbo wheels are 7.5" wide, the 300zx Turbo the Two Rear wheels are 8.5" wide, that will not fit on the ES300.
lol, i watched your Youtube video about Timing belt and Water pump replacement 2 weeks ago. thanks for the Video, It was easier then looking at the book.
Originally Posted by speedkar9
Looks great.
Old 10-07-15, 06:38 AM
JetsonES
JetsonES's Avatar
He makes some great videos, for sure.
Old 10-07-15, 06:55 PM
speedkar9
speedkar9's Avatar
7.5" isn't too wide for the ES300? I've got 7" wide wheels on my Solara (same suspension setup as the Camry/ ES) and the 215mm rear tires are barely rubbing the struts. What offset are you running without spacers?
Thanks
Old 10-07-15, 07:14 PM
Chocolate
Chocolate's Avatar
Thanks
I had no rubbing issues when I had 225/45/18s on 18x7.5 wheels with no spacers on my ES 330.
Old 10-08-15, 02:19 AM
vietbboy85
vietbboy85's Avatar
45mm offset, i run it with the 205/60/16 tires. Its about 8mm gap between the tire and strut. If i run it with the 215mm tires i think its would rubbing the struts. its would be nicer with the 215mm tires, but i dont want to put the spacer on the rear wheels.
Thanks
Old 10-08-15, 07:00 AM
JetsonES
JetsonES's Avatar
I am running 8.5" Sc430 wheels and only got slight rubbing on the rear over extreme dips and bumps. A 5mm spacer cleared it up but I may reduce section width on the next set of tires to see if I can eliminate the spacers
acc
07-17-10 12:03 AM
Audacity
02-28-10 11:04 AM
Audacity
10-28-09 06:04 PM
CLCC
04-03-05 12:40 AM
Quick Reply: lexus es300 with 300zx wheels
