Marvel Mystery Oil
Old 12-24-15, 01:00 PM
mmatheny
mmatheny's Avatar
There goes the mystery!
Old 12-26-15, 02:09 AM
Oro
Oro's Avatar
a good friend of mine(who was a toyota master tech through the late 80's to mid 90's) said that marvel mystery oil is just a mix of diesel and ATF. I dunno if I'd leave it in the oil beyond using it for a flush.
Well he was wrong.
Definitely no Diesel in it; the sulfur and wax content of diesel is a dead give away and not present in MMO. Wintergreen oil is clearly present just from the unique odor. It could potentially have some kerosene in it, but that's different enough from diesel to not be confused.
Old 12-26-15, 10:03 AM
mitmaks
mitmaks's Avatar
yes, definitely smells like Kerosene.
Old 12-26-15, 07:10 PM
atlcal
atlcal's Avatar
If you're really interested in oil, and additives, check out www.bobistheoilguy.com. Way more chemistry knowledge there than I could dream of learning in this lifetime. One of the threads listed the following:
70% Light Aromatic Oil (Pale Oil)
- It is a Naphthenic Oil, so while it oxidizes faster than a Paraffinic oil, it does clean and dissolve sludge and carbon well and cleans up after itself from any oxidation. serves as base oil as well. [Naphthenic oils have more solvency and are more polar (they are attracted to metal more), but oxidize faster.
29% Mineral Spirits
- Cleans Varnish very well. General cleaner. Also acts as an antioxidant.
38 parts per million (ppm) Boron
- AW/EP agent, friction reducer, antioxidant
900 ppm Phosporous
- AW/EP agent
1/2% 1, 2 ortho-Dichlorobenzene
- EP agent as it interacts with Iron to form an Iron chloride barrier under any ZDDP or other AW additives. Also very good cleaner/solvent, and friction reducer
1/4% 1, 4 para-Dichlorobenzene
Oil of wintergreen - for the scent
- Not just for the cent, is also a cleaner. may aid lubricity.
Red Dye - for the color
- well this one just colors the stuff
Full thread here: http://www.bobistheoilguy.com/forums...Number=1835056
Marchela
HS 250h Model (2010-2012)
03-29-24 10:03 PM
drifto
09-19-16 02:59 PM
David98GS
02-05-08 07:59 PM
sha4000
11-28-05 01:36 PM
FusionMan79
09-01-02 12:17 PM
Quick Reply: Marvel Mystery Oil
