How to replace to take out the Front corner signal housing?
thx..
i unscrew the screw on top of the housing.. but i have no idea how to pull it out...
how do i remove the whole corner housing after the step of unscrew...??????
btw mine is a 97 model......
thx..
thx..
after you get the screw out, there are two choices. on the side of housing closer to the the center of the car there is a tab, push it back and it will come out. that is the hard way. The easy way is get your fingers under side housing and just pull and it will pop out, may need to wiggle a little.
thx very much..
but where is the clip..?
which way should i pull... 1 or 2...?
hope u understand my graphic...heehheh i knw it is kind of ShXXt....
ninjabrad
11-18-11 12:39 PM
