Did I get a good deal?
Old 11-11-15, 07:36 AM
  #31
JetsonES
JetsonES's Avatar
The exception would be staggered wheels. That would throw a wrench into things. My old mr2 had wider wheels in the back than in the front so it would be weird to change them out. They were 14" though so I don't think anyone was clamoring for them anyway.
Old 11-11-15, 09:45 AM
  #32
01LEXPL
01LEXPL's Avatar
Originally Posted by JetsonES
I have SC430 wheels on my ES300. They were $250 with 50 to 60% tread left on the tires. I needed new tires at the time so it worked for me. A quick look at the local dfw Craigslist shows the following under "oem lexus wheels" you could also search "oem toyota wheels" as they will pretty much all fit. You just have to check Craigslist a lot as the good deals go fast. I have seen cheaper in the past. There are also more sets but I limited my post to $500 or less. Some crackheads want $2000 for their old stock wheels, I have a feeling they will be sitting on them a while.
WOW! Those are CHEAP. Dummies still SELL their chrome 2GS rims in Canada for around 5-600$ all day long. Stupid.
I've been looking for a set of chrome ES350 wheels, nope. Can't find them. And if they come up it's usually 1500$ with new-ish rubber.
Looks like I will have to look in the US.... and just drive down lol
Originally Posted by Zacharias
So if I understand this, the wheels for Lexus RWD and FWD models interchange?
That is rare but it sure makes life easier!
Not exactly....
Hub bore of 60.1mm - yes, all across the board [maybe LS460, and the 6lug SUV's]
Bolt patterns - see above, for COMMON sedans, it's all the same 5x114.3 - except LS460/CT/HS hybrids with 5x100 [prior LS' yes]
Offsets, the offsets on RWD cars are usually higher in the rears - this becomes tricky for FWD cars since the [es in particular] has very tight clearances in the BACK for suspension components.
Widths - staggered, usually 0.5" bigger in the back for OE applications. Not overkill BUT concerning offset AND widths, this may not work out for the ES, which is the only FWD sedan.
Preferably, you want painless and guesswork-free? Get something from any RX, 3GS, Any ES, OLDER LS [01-06], 07+ IS non-staggered.
Those will bolt right up, even use the same lugs... unlike aftermarkets which require spline/tuner lugs to fit & hubcentric rings.
Basically, be careful with the staggered IS fitments. On the 3ES they didn't clear the rear. I don't know how forgiving the 4es is...
Old 11-11-15, 10:48 AM
  #33
JetsonES
JetsonES's Avatar
Thanks for the info 01 LEXPL, I would suggest that anyone switching wheels do their research and find out width and offset first to see if they will fit. On mine the clearance is very tight in the rear but only rubs under big bumps or dips. I think it can be resolved with a narrower section width but for now I use 5mm spacers.
Old 11-11-15, 08:13 PM
  #34
RTF
RTF's Avatar
Originally Posted by Goldenhunt
I think that it is only trifles. The seat can be to stick with something, but the door - well, what do you want? the machine is not new. It seems to me that this is sounding like an option for beginners. Somebody will take.
I love it. I was just wondering if I got a good deal
Old 11-12-15, 06:10 AM
  #35
mmatheny
mmatheny's Avatar
Originally Posted by TomsCelica
Someone try to pry the door open? People are pathetic
Looks more like someone hit the door while it was open or it got backed into something - notice no marks on the body.
Old 11-12-15, 07:01 AM
  #36
JetsonES
JetsonES's Avatar
I got the same type of damage moving a car backward out of my garage with the door slightly opened. Hit the edge of the garage door rails and that was that. I don't even recall why I was doing it. I do a lot of stupid stuff with cars.
Old 11-12-15, 10:41 AM
  #37
mmatheny
mmatheny's Avatar
Ahhh - my younger years
Old 11-12-15, 10:53 AM
  #38
JetsonES
JetsonES's Avatar
I still do. An ES300 WILL NOT go where the rented Jeep Wrangler I had will, not even close. Lol. It is so toast.
ES300NZ
62
01-11-15 10:32 AM
Vh_Supra26
15
03-01-13 11:49 AM
IamLexus
10-04-12 02:47 AM
hypervish
32
07-29-12 08:17 AM
kaldES98
22
05-31-10 10:47 PM
Quick Reply: Did I get a good deal?
