Replaced fuel pump, now gas gauge doesn't work
Old 11-17-15, 11:19 AM
crwys
crwys's Avatar
Default Replaced fuel pump, now gas gauge doesn't work
Hey everyone, just replaced my fuel pump from a friends 2000 Toyota Avalon to my 99 lexus es300 and now my gas gauge doesn't work. The needle is dropped all the way down. I plan on buying the oem fuel pump for my car but just in case this isn't the problem, what else could it be?
Old 11-17-15, 12:06 PM
JCC511
JCC511's Avatar
I would think there is a sending unit of some kind that communicates with the gauges. Maybe that is a separate piece that is not the same as what is from the Avalon.
Old 11-17-15, 04:46 PM
808mcv20l
808mcv20l's Avatar
this is definitely the fuel sending unit.
I have not seen what it looks like on the ES300/Avalon, but on a Honda the fuel sending unit is attached to the fuel pump housing that gets submerged into the tank.
The fuel sender usually has a metal arm with a "float" which on the end of it makes contact with a circuit board that tells the gauge what the fuel level is.
I would double check your connections or the fuel sender from the avalon could be incompatible or broken.
Old 11-17-15, 06:20 PM
KING
KING's Avatar
Yup, I would double check connections and go back and see if everything was hooked up correctly. Sounds like it should work.
Old 11-17-15, 07:30 PM
crwys
crwys's Avatar
It must be incompatible then. Because the Avalon gas gauge works just fine as well. Ill go back and double check though. Thanks everyone.
99gs713
12-17-13 08:10 PM
Bankswood
SC- 1st Gen (1992-2000)
03-26-13 06:51 AM
NSeagle78
Performance & Maintenance
08-26-12 08:51 AM
thegr8one
11-16-10 01:22 PM
acenase
08-31-07 07:02 AM
Quick Reply: Replaced fuel pump, now gas gauge doesn't work
