Severe Belt noise and squeaking at start up and cold temperatures.
Hey folks Any help would be appreciated. Upon start up of my 2001 es300 belts squeal terribly. Spray some liquid soap around all the pullys and it stops only for a moment. Can lack of tension cause this? Belts are in fine condition.
Thanks
Tommy329
Thanks
Tommy329
There are a bolt that you have to loosen before you can tight the adjusting bolt. They are right under the alternator. You can access both bolts from on top....hopefully you have small hands.
Thanks for your help. I actually found the video you posted on youtube. My problem is the tensioner bolt on the alternator was snapped off by a pervious owner. Any suggestions? I can provide a photo if needed.
Should be an easy fix there is a slider block and a bolt is that what is broken? Here's the part numbers:
slider - 16385-20010
bolt - 91511-B0845
adjusting bolt - 90080-11617 (this is the long bolt)
bolt - 91511-B0845
gtstcactus
04-12-15 06:50 PM
