What are EGR "tube" gaskets/gasket?
Preparing to do plugs and valve cover gaskets. Reviewing Speedkar9's excellent DIY:
https://www.clublexus.com/forums/es-...placement.html
Listed as needed are:
- EGR valve and tube gaskets
I have an EGR gasket I find, but don't understand the "tube" aspect. I've worked on EGR valves before but don't recall anything special beyond the base gasket. What am I looking for here or am I misunderstanding something?
If you are talking about your '02 ES I don't think it has EGR just a plate which you don't need to mess with.
His demonstrator in the DIY was a 99 Solara IIRC, so there may be differences.
There is an EGR gasket listed in the parts catalog; it was like a $1.20 so I can add it JIC.
Thanks for the reply; I'll not worry about it then.
There are 3 gaskets, one from the EGR connecting to the Intake manifold, another from the EGR to the EGR pipe, and the last one from the EGR pipe to the exhaust manifold.
They are 3 identical metal gaskets, but again this is info is from a 99 Camry V6.
I looked it up a 2002 ES has no EGR valve.
CF01
12-26-15 02:03 AM
StuckInVA
04-21-13 07:00 PM
