I'm not sure If my heated seats work?
I just bought a 97 ES300 and I tried the heated seats...after about 3-5 minutes they get a little warm but I can barely feel it through my clothes. I touch the seat and it is not that warm. Is there like a control switch for it or something? In the manual it says to be careful because it can cause burns and uncomfort to some people. Are mine bad? Thanks
Lexus Connoisseur
Either the heating element is going out or a fuse controlling it is about to go.
Also keep in mind that it is about 60 degrees out right now where I live so maybe it is just becuase it is warmer out that it feels weak? Can I do anything about the heating element or fuse controlling with out spending too much? Thanks
i have the same problem i hardly feel them unless doing a highway drive for over 30 minutes the alternator is not putting full charge all the time for my problem
if i hook up a charger to the car it works real nice
the heat is much more than normal when driving the car
but i have never been in an es that had a good seat heater
i also don't intend to sit in my garage for heated seats
you might want to get a alternator test
try and do it when the engine is hot as there is a high heat resistance problem that occurs more at idle and hot
i haven't had time to take it to a rebuild shop to let them trace the inner cicuits of the alternator
The heated seats on my '94 ES was always very weak from the first day that I purchased this car new. I complained to the dealer about this and he told me that this was normal, so I learned to live with it. On the other hand the heated seats my new '03 ES works great. They must have improved something because of alot of complaints.
Alan
Alan
