How bad is it to floor your car?
I'm wondering because I always feel really bad and guilty after I do it. I try not to do it much but sometimes it's really hard to resist. I also want to do some performance mods to my car in the future but if it is really bad to floor your car then I probably won't because it would not be worth the money. Thanks
Not bad and don't feel bad just make sure your car is running in good shape cause flooring it runs it hotter and the trans and coolant get hotter faster and you want the car properly cooling the fluid and cleaner newer fluid works better under your hard driving then fluid that is dirty and in need of a change, hence overheating
One more tip is I usually coast home the last mile or 2 to give the engine time to cool rather than just turn it off at it's hottest
Super Moderator
i think it depends.
if you are gradually accelerating, and eventually get to the point where the pedal touches the floor (its flooring still, right?), it's better than going from a dead stop and flooring it suddenly. what wear THAT must be on the tranny/torque converter.
mezoom and steviej explained well
it is a good idea to open a car up ,just there is alot more force placed on a car when this is done from a dead stop
by opening up or WOT ( wide open throttle) the engine is ingesting large volumes of air and gas at a fast rate this is good as it helps to remove debris and carbon buildup from the chanber and valves
which will lowers gas milage and performance
so a good highway drive is a really good thing 40 minutes straight is close to doing that also but not as forceful to remove tough debris
a good time is when getting on to an on ramp when already moving slow
if it is a straight one ,to open the car up and then slow down a bit to get to rated speed of the road
atleast that is what i like to do
short drives especially have a larger bulid up of varnish in the intake( from cold start increasing the amount of fuel ,so when the car is turned off the gas vapours just sit in the plenum intake(evaporated gas leaks by the valves into it as they are open) as the throttle is closed keeping it in their to become varnish deposits
this usually takes a good intake spray cleaner to clean up as it is before the injectors and fuel treatments cannot reach them( also will help rough idles)
my wifes car is 5 minutes a day driven i have to clean the tract every 6 months and it almost never goes on the highway
Lexus Connoisseur
acklac7
Performance & Maintenance
12-20-17 10:03 AM
ckwasi92
27
04-27-14 09:40 PM
