05 Lexus es330 passenger front door stuck
Okay so my passenger front door is stuck shut and won't open from the inside or outside. I've already removed the door panel as much as I could and could see the door lock actuator. I was able to get a long flat head down there and push the door opening mechanism but still no luck. The door is jammed shut! Now what I was thinking of doing was just breaking the plastic cover to the actuator just enough to open the door and replacing it? I would really like to get some advice as to know where I should go from here. I've researched this a bit and it seems to be a common problem with these models. I'm pretty sure someone here as experienced this same issue. Thanks in advance fellow Lexus drivers.
jdub20tx
Performance & Maintenance
10-28-10 05:53 PM
