toyota camry spark plug torque same as lexus and what is it ?
gonna be doing a 2003 Toyota camry 2.4l using denso SK20R11 plugs I was wondering what the torque spec was ?
My 99 es300 owner manual says NGK or Denso. Gap at 1.1mm (0.043 in.)
Edit:
Lol my bad thought op was asking for gap. I'm tired. I'll leave the above information just in case.
Edit:
It is not totally necessary to torque down spark plugs. Youre not driving a nascar. Tighten them GENTLY until they stop, and give about 1/4 a turn for tightness. I would be more of afraid of a messed up torque wrench ruining a head and stripping threads in aluminum than doing it by hand.
on my Honda's I've always done them to 16ft lbs with a torque wrench and never a problem. always add a bit of anti-seize on threads will save you a ton of headache later if they get seized in from corrosion.
this guy said he used 13 ftlb
http://www.toyotanation.com/forum/10...-plugs-ok.html
