Best Spark Plugs and Wires for a 2006 ES 330?
Hi I'm planning to change my plugs on Friday. I'd like to know which is the best option between Denso, NGK, and Bosch?
I read somewhere that Denso plugs are OE. Can someone confirm that?
Also, do the plugs come with wires or are they sold separately? If separate is there a preferred brand?
Thank you!
Thank you!
Denso Iridium Long Life, is what most people install.
There shouldn't be any wires to change as each cylinder should have a coil on each.
Go with Denso or NGK for your japanese car, you can't really go wrong with those brands.
Denso SK20R11
Cost no object, use the Denso Long-Life as mentioned and the p/n given.
I am currently using the equivalent Autolite plug as it was both on sale and on rebate and when all said and done, just under $2/plug. For that price, I had to try them as I have seen them give good service in Isuzu and Acura vehicles. The Car runs fine but I only have 1k miles or so on it so far. I believe the rebate is good through the end of the month.
kevs
03-12-05 07:55 AM
