Timing belt noise 05 Lexus ES 330
#32
Reviving an old thread here;
I recently changed the timing belt on my '05 and it developed the same noise as the posted videos above.
I don't mind living with the noise as long as it won't end in anything catastrophic.
Have any of you guys just decided to live with the t-belt noise with no issues?
#34
Problem I found in stubborn cases is to get all the old material off I also removed the anti corrosion coating. Oven cleaner will remove most of the belt gunk but also seems to damage the coating if you leave it on long enough to dissolve the rubber.
Hayk (07-21-21)
#35
As i've said in my previous post, I don't mind living with the noise as long as it won't cause premature failure.
My question is.. Anyone decide to just live with the t-belt noise with no issues?
Do I really want to pull the t-belt back out and clean pulleys for a harmless noise? Hell no.
#36
Noise won't cause any problems and it might even go away eventually as the belt wears.
msekanha (08-17-21)
sayow
35
12-23-13 04:02 PM
