P1325--ignition circuit fault #6
1999 ES 205,000 miles shows a P1325-ignition circuit fault #6 code. 150 compression-- wires from coil to harness ok...according to flow chart, problem is either ecm or wire harness. Is there something I'm missing in diagnosis before I try throwing parts at this? On cold engine flashing check engine and trac lights sometimes come on only after short run. Removing neg terminal for short while to reset check light and car may then run 200 miles or more without reappearing check light. Anyone have this similar kind of problem?
Thanks,
Codger
Thanks,
Codger
My 99 ES300 has 370k with original engine and rebuilt trans. Last week the car went into "limp mode" and then I replaced both cam sensors, then Crankshaft Position Sensor. No help! Just replaced ECU with new and still no help. All 6 igniters and coils are throwing intermittent codes....LOST!
Codger
Gtfourever
04-30-16 08:14 AM
