How to replace Top corner lights 05 Es 330?
You will need a small child.
Really. They are idiotically designed and one of those "should last past the warranty" kind of things Toyota increasingly employs, GM-style. I had to get a neighbor with small hands to do it.
I think the factory method is to remove the bumper cover, radiator/grill inner trim, then headlight housing.
Easiest way is to turn the wheel all the way inwards, remove a few rivets from the wheel well, and you should be able to reach the bulb. It's a 194 bulb, I run 7.5W ijdmtoy LEDs in there, will match your xenon nicely. I routed them to the turn signal area for a while as DRLs before my quad projector upgrade, now they're back in the original spot.
Attachment 493044
Attachment 493045
Check out this relevant thread:
https://www.clublexus.com/forums/es-...ior-led-s.html
Attachment 493044
Attachment 493045
![](https://i.imgur.com/dfIAJgW.jpg)
![](https://i.imgur.com/ZCeoUIH.jpg)
That's what I did, there are some details in the thread I linked. I did put them back in the original place since though for now.
