bank 1 sensor 1 and bank 2 sensor 2 are they the same?
Old 03-04-16, 06:54 AM
lexlude
lexlude's Avatar
Default bank 1 sensor 1 and bank 2 sensor 2 are they the same?
I have a 98 es300 and I get code p0171 off and on. The code comes and goes away by itself. I was thinking about switching around the two a/f ratio sensor. I tried cleaning the maf, I tried another used maf and then I also tried a new aftermarket maf and I still get the p0171 code intermittently.
Here is a snapshot
Attached Thumbnails bank 1 sensor 1 and bank 2 sensor 2 are they the same?-20160217_075841.jpg
Old 03-04-16, 08:22 AM
DRACO A5OG
DRACO A5OG's Avatar
No they are not, one is in front, easy peasy next to the exhaust manifold, bank 2 sensor 2
The more difficult one is the bank 1 sensor 1, you guessed it, it is in the back of the engine next to the firewall. Joy. it can be done but just a PITA
Remove the Sensors and if full of crud, burn it off with a torch. Test again with a torch and a DVM to see f moving the flame over you get 1 volt, if so then it will still be good after cleaning. If not, time to replace. Do not drop it or you will break the internals.
Old 03-04-16, 09:00 AM
PFB
PFB's Avatar
I think the sensors themselves are the same, but the cable length may be different
Check online to see if they have different Part numbers
Old 03-04-16, 09:14 AM
lexlude
lexlude's Avatar
Ok I will check the cable length and also check to see if it need to be clean
Old 03-04-16, 03:26 PM
artbuc
artbuc's Avatar
Wrong. B1S1 and B2S1 are the same except for harness length. The "easy peasy" in the front is B2S1. B2S2 is the downstream oxygen sensor. Is your car Calif emissions? If yes, your upstream sensors (S1) are the much more expensive A/F wide band sensors.
Old 03-04-16, 03:56 PM
DRACO A5OG
DRACO A5OG's Avatar
I stand corrected.
Old 03-04-16, 05:49 PM
lexlude
lexlude's Avatar
The California standard slip my mind. Couple years ago a friend of mine bought a used 97 camry. Check engine light came on couple months later for o2 sensor. I went to replace it and notice that the previous owner recently changed it.
Year later same code. I went to buy another and the parts guy asked as usual if it was California or federal emission. I usually say federal since I live in NY. This time I went to check under the hood and it said California emission. I bought the correct o2 sensor and never got the code again.
Since I live in NY I assume my es300 is federal emission. I will have to check under the hood tomorrow
Old 03-05-16, 01:15 AM
artbuc
artbuc's Avatar
Where you live or where you bought th car has nothing to do with its emissions. I bought my 99 Avalon brand new in Delaware and it was Calif emissions. I believe emissions is based on the state which imported the car.
Old 03-05-16, 04:11 PM
lexlude
lexlude's Avatar
Well I was thinking vehicle sold in California have to meet California strict emission standard. Those vehicle found its way all over the country somehow. I checked my es300 and it's. California emissions too. I change 02 sensor couple years ago and right now I don't know if I put the right one in
Old 03-06-16, 12:55 AM
artbuc
artbuc's Avatar
Yes, of course a car purchased and registered in Calif must meet Calif specs. I was talking about cars purchased in other states which may or may not have been built to meet Calif specs.
Old 03-06-16, 08:09 PM
DJPsystems
DJPsystems's Avatar
This might sound strange but my 97 ES300 that was sold brand new in CA uses federal spec 02 sensors. I found out the hard way when I ordered CA spec 02 sensors (Denso 234-9007 and 234-9009) and the connector did not fit, it was different. The proper sensor is Denso 234-4622 for bank 1 and 2.
topgun129
13
11-19-14 09:50 PM
lcc014
04-05-13 06:38 PM
palaka
RX - 1st Gen (1999-2003)
02-21-08 10:27 AM
lockie
11-23-07 06:31 AM
palaka
09-03-07 06:58 PM
Quick Reply: bank 1 sensor 1 and bank 2 sensor 2 are they the same?
