Transmission question
So, if I'm driving in stop and go traffic, and after moving forward a bit and letting up on the accelerator, then pressing it again to move forward, the transmission acts like it disengages then bangs into gear. Almost like the clutch disengages then re-engages when the throttle is advanced. Really bad a low speeds. Higher speeds it doesn't seem to do it. Any ideas?
I got the pan dropped and filter changed and new fluid added about 4 months ago (probably around 56k). I'll check the level. I would assume the transmission place would know the type of fluid, but who knows? I'll contact them. What kind SHOULD have been used?
There was a post here last year where someone replaced their filter with an aftermarket one from the shelf of a local auto parts store. The paper filter was too restrictive and starved the oil pump. The symptoms you describe could be to due to low fluid, incorrect fluid, or pump starvation. He switched his OE filter back in and problems went away. FYI, checking fluid level on a transmission is not like checking engine oil. The fluid needs to be hot, the engine running, and you need to do it after shifting slowly through all gears.
The factory fill on these was Toyota T-IV fluid, which was a Dexron III-based fluid. T-IV has been superceded since then. Many fluids will meet the T-IV spec for these cars so as long as a minimal level of competence was used, a compatible fluid is not hard to pick. If you do need new fluid, there are a lot of people very happy with Valvoline's MaxLife ATF - very affordable in gallon jugs at Walmart and some Autozone stores.
Just talked to shop that did the flush - if it has a screen filter they flush it and put it back in. They use Dexron III or better - I need to talk to owner to see exactly what fluid was put in mine. Tech ALSO said it sounds like low fluid. I'll check that when I get home. Thanx for all the input! This is a GREAT site!
I know at 99 it can be dex iii or t-iv.
Before 99 it's dex iii
2000 - 2003 I think, it's t-iv.
Or if you count the bolts on your transmission pan.
17 = A541e transmission, dex iii
18 = U140e transmission, t-iv
Shop said they put Coastal full synthetic fluid in. I checked the level and it is fine. Speedkar - I remember seeing somewhere there is a firmware update for the transmission that corrects some shifting problems - but I also read it can also make it worse - opinions??
Found THIS:
http://us.lexusownersclub.com/forums...op-and-go-tra/
However, it is NOT a hesitation - it literally acts like the clutch disengages then engages hard when I give it gas. Could a low idle speed cause this - my idle speed is barely above 500. I need to thoroughly clean the throttle body to see if that will fix it. Anything else to check for low idle?
Just looked at the Lexus maintenance records, don't see any transmission reflash BUT do see where owner requested a drain and refill at 25442 and 38446 miles, so maybe he was experiencing the same issue. Maybe that's why they got rid of it a 54k!!
Reading the documentation for Coastal Full Synthetic ATF, it is compatible with T-IV:
Toyota / Lexus / Scion Type D-II/T-T-III/T-IV
http://www.google.com/url?sa=t&rct=j...Ez6Qxxf95e3uCw
It's just weird (and scary) because I can make it slam pretty hard if I let up then pop the accelerator!
