How to get to Ignition Coil #5
Old 03-21-16, 11:27 AM
ojmoncrief
ojmoncrief's Avatar
Default How to get to Ignition Coil #5
Having a misfire that's coming from my ignition coil #5. Need step by step help getting to the coil. Thank you
Old 03-21-16, 12:57 PM
artbuc
artbuc's Avatar
https://www.clublexus.com/forums/es-...placement.html
If you only have to access #5 you can probably just remove the TB and leave the air plenum alone. However, sometimes codes are off a cylinder and it would be good to have access to #3.
Old 03-23-16, 05:16 PM
DRACO A5OG
DRACO A5OG's Avatar
When car is cool, just reach behind there. Tight but you can do it. Heck you can see from the TB side.
Old 03-24-16, 12:57 AM
artbuc
artbuc's Avatar
Are you talking about your 96 ES300? Major difference between a 96 and 03.
OP, what year is your ES?
Old 03-24-16, 06:38 PM
speedkar9
speedkar9's Avatar
If you've got the 1999 ES300 then you can reach the plug behind the plenum. You might have to remove the air hoses.
Old 03-25-16, 12:45 AM
artbuc
artbuc's Avatar
Toyota V6 Spark Plug Replacement - YouTube
You may be right although just because you can do it on a Camry does not mean you can do it on an ES300. In either case, the 03 ES with the plastic plenum is a totally different animal.
mzeitlin
08-12-16 08:29 AM
jokesock
07-02-16 09:55 AM
Billiamch
04-11-16 01:31 PM
MKLEX
Maintenance
08-25-05 05:21 PM
lextune23
27
09-24-03 07:58 AM
Quick Reply: How to get to Ignition Coil #5
