Higher RPM's with 20" rims.....
I'm turning 4000 rpm's @ 60 mph, I know for certain this isn't normal. Yes I know I've change the factory setup by changing the rim size, but can anyone offer some good advice on what I can do to fix this?
Tire size are 235/35 oddly enough I got it out of paint yesterday and it was turning those rpm as stated before and now I'm driving it this morning and it's seems to be a little lower at about 2750@ 60 mph, on my way to my mechanic for tune up oil change etc. There was a p0330 knock sensor code in there for bank 2 circuit 2.
How did you know what gen car he had? He may have t 4th or later gen with 5 gears.
POSTERS - We can help you SO MUCH MORE if you would just put your model year in your signature or in the post!
If you are getting over 4k rpms going 60 and you have the knock sensor code I would definitely say it's stuck in 3rd gear cause no over drive.
If you are getting 2750 rpms going 60 you have a different problem.
I use to have overdrive problems and specifically remember a little over 4k rpms on highway which is why I mentioned it.
And yes providing model and year is definitely helpful.
Deathrow23
05-10-22 01:31 PM
CASANOVA86
Performance & Maintenance
26
08-31-10 02:17 AM
