Failed ECU/ECM
Old 04-18-16, 08:06 PM
rajes300
rajes300's Avatar
Default Failed ECU/ECM
Hi,
The ECM on my 1995 ES300 went bad last week. I've taken it to my local mechanic. Although he has been able to diagnose that ECM and Solenoid in the transmission to have gone bad, he is not able to find a replacement ECM. The main reason he says is he needs to find an ECM that has the paired key along with it. I've searched to the internet for the part. I stumbled on to couple of websites that say I can just plug their ECU in and drive the car without need for anything else to do such as reprogramming. This has confused me. I'm not sure if the websites' claim are true. I desperately need this part as it is the only car I have.
Can someone please guide me. Is what the websites' say is true? If not, where can I hope to get an ECM as per my mechanic's requirement. Another option could be to buy a computer and reprogram it but then I don't know where to get that done.
Any help would be great. Thanks in advance.
Regards
Old 04-18-16, 08:52 PM
Received 3,033 Likes on 2,548 Posts
From what I remember your year of ES did not have the immobilizer so you don't need to worry about programming the ECU. Grab one that matches your part number (or a compatible number) you should be good to go.
Old 04-24-16, 02:01 PM
Ultramiler
Ultramiler's Avatar
I am not sure about your year, but I have read the same thing about needing the key for 1999 ES. How has the ECM failed? What problem is it causing?
There are some companies that rebuild them, so you would get your same ECM back and no programming would be needed. I am not sure what they actually do to rebuild them though.
ajs1391
03-01-16 08:26 AM
LexBrett
09-20-15 03:56 PM
Diwill05
24
05-22-14 05:10 PM
ez345
07-27-12 10:50 AM
hit42
IS - 1st Gen (2001-2005)
04-19-12 08:53 PM
Quick Reply: Failed ECU/ECM
