What is this noise?
97 Lexus ES300
Noise documented here:
I've had this rattle since I've owned the car-- about 6 months.
I've replaced the ball joints (other issue but thought it could be this), torque strut mount, and sway bar links.
I have sway bar bushings but they looked OK and the tie rods were in the way so I didn't replace em.
I'm thinking it's time to move to more expensive things and look at the struts and mounts.
Any ideas?
Any ideas?
I remember reading this tread and it was something simple. Hard to tell with the recording but maybe worth a read. Good luck!
https://www.clublexus.com/forums/es-...ion-noise.html
Thanks!
It does sound like a stabilizer linkage. Did the rattle remain completely the same after replacing it? Are you sure its coming from the front and not the rear linkage?
Does it sound like its coming from outside or inside the vehicle? It could be a loose dashboard panel too.
Usually strut mounts make a louder clunk or poping sound when they're busted.
However, I replaced BOTH links at the front (driver and passenger) and nothing is rattling from the front driver side :/
shbaki
05-24-19 04:36 AM
Dorian7
16
03-17-15 03:30 PM
Coulter
33
02-04-13 07:38 AM
