Installed new head unit, rear speakers don't work....
Old 05-12-16, 02:04 PM
XclusivOne
XclusivOne's Avatar
Default Installed new head unit, rear speakers don't work....
Like the title says after installing everything, I only get sound out of the rear speakers when the subwoofer setting is on in my new pioneer head unit. Also, now that the radio is installed when I lock my car, it no longer beeps. I don't know whats going on, PLEASE HELP
Old 05-12-16, 02:08 PM
WILLYumD
WILLYumD's Avatar
Please list your head unit, car model and feature-set (Nakimichi, Mark Levinson) so others can help you.
Did you use a wiring harness adapter and does your HU support 2 sets of preouts (or 1 set that you used a Y connector for)?
Also, from personal experience, my 98 ES300 has a **** under the steering wheel that can be turned to control the volume of the lock beep, have you played around with anything under the dash?
Old 05-12-16, 03:08 PM
XclusivOne
XclusivOne's Avatar
Okay, so I figured out the beep. There's a volume **** under the dash. The factory head unit was the American one. I didn't see Mark Levinson or Nakimichi anywhere. The head unit I got is a pioneer fh-x720bt.
Old 05-12-16, 04:41 PM
WILLYumD
WILLYumD's Avatar
Are you sure your wiring harness is done up correctly? Make sure you connected the right colors together. (Quick Google search showed that some people connected their blue power antenna wire to the harness instead of their blue/white amplifier wire. Something similar could be happening in your case.) Is your HU grounded to the chassis?
For anyone wondering and can maybe help, XclusivOne has a 2000 ES300 Platinum, most likely a Pioneer system and the troubling speakers are 4 ohms, which the HU is rated for.
Old 05-12-16, 04:47 PM
XclusivOne
XclusivOne's Avatar
Wow, thanks *****! Yeah I wired the blue with the blue AND the blue/white! I'm guessing the blue/white should be isolated?
Old 05-12-16, 05:11 PM
WILLYumD
WILLYumD's Avatar
According to Metra (assuming you purchased a Metra harness), the blue and only blue wire is for the power antenna. The power antenna is a feature we don't see on the 2000 ES, so it should be isolated.
Optional:
Also note that your HU's illumination probably won't be linked to your car's lights (turning on head/taillights won't affect the screen's brightness) so you can fix that while you're at it. The only problem is sometimes you'll have to modify the harness which is a very annoying task in itself. (You have to take out one of the pins of the harness, e.g. the blue one you're gonna isolate, and move it to the place where the Orange/Illumination wire would be.)
Old 05-12-16, 05:47 PM
XclusivOne
XclusivOne's Avatar
Okay, I'll do that. But I still get nothing out of my rear speakers when I turn off subwoofer
Old 05-12-16, 05:58 PM
WILLYumD
WILLYumD's Avatar
Just took another look at your manual, is your SP-P/O mode set to REAR/SUB or SUB/SUB because the former is the one that should work.
And while REAR/SUB is set, play with your REAR-SP setting. I'm not familiar with any of this but FUL or SW may produce better results.
Old 05-12-16, 06:10 PM
XclusivOne
XclusivOne's Avatar
Awesome, I'll check it out
Old 06-17-16, 02:19 PM
XclusivOne
XclusivOne's Avatar
So its been a month, and I was able to resolve the speaker issue, and install a 10" Kicker Comp VR sub. So far everything is working beautifully, and I also installed the 10K PNP HID kit for the lows... Loving this car so far.
Masikr
06-22-16 08:41 PM
wbmx1981
09-26-12 08:40 PM
jdog0411
04-11-11 01:11 AM
jerryparks
10-08-10 06:08 PM
Stage3
15
10-10-08 08:55 PM
Quick Reply: Installed new head unit, rear speakers don't work....
