2001 rear calipers
2001 rear calipers
How the heck do I remove the calipers?
I have the one bolt out and it pivots but I can not slid it in or out.
Pivot the caliper upward and then pull off. If you can't do this the slide pin has seized. You may have to remove the bracket from the backing plate (caliper still attached) then you can work with it on the bench.
I remember now. I disconnected the brake line, unbolted the bracket and removed the whole rotten mess. The new calipers came with everything needed. Didn't put a whole lot of effort into freeing them up, I was afraid of breaking or warping something.
Armitage
05-23-17 01:36 PM
masboy
Maintenance
11-04-12 07:04 AM
