96 ES300 Master key without transponder?
Hi all, I bought a 1996 ES300 and it came with just one key. This key doesn't have a remote button on it, so it should be the service key. But it opens the boot, and locks the glove box.
This isn't right, is it? Is it actually a master key in disguise?
Remote button? Back then, Lexus keys were separate from the fob with the buttons. Is the key black or gray
I'm in Australia so things might be a bit different. Here, for 1996, there is a master key with a button on the side for the remote, a valet key with no button, and an emergency key for your wallet.
As I bought it, I have just the valet key, mine is black. BUT, it opens the trunk and glove box. Can this be right?
There can be a master key that does not have the transmitter in it. The factory part number for the Lexus key with transmitter is 89742-24070 your car will have to be programmed to accept it.
This forum is the best!
If you can post your VIN otherwise I can't be sure that is the correct part number.
<QUOTE>If you can post your VIN otherwise I can't be sure that is the correct part number</QUOTE>
Sure thing. It's JT762VV1000260878
Hope that helps. Thanks.
Same part number comes up for that VIN 89742-24070.
I hope this works out for you those keys are not cheap. BTW I didn't see any reference to a transponder in the parts diagrams could be wrong but I couldn't find one.
Yeap, 96 had a remote key, sucka is expensive $450 at the dealer. My stepson decided to loose it so I went to the dealer and just got non-remote Master for $85 made couple of copies just in case he loses his mind again.
305Busa
04-26-15 02:00 PM
